AmericanThunder
Super Moderator
Great news on the MOT
Done a little more tweaking today.
took it to my aunties, she was really happy to see it, and Mum heard it come up the drive, she is bed bound, but was very happy to hear it near.
Made some adjustments to spark timing, also went for a longer run and data logging.
Need to take a bit of fuel at the lower loads, but add some at the higher end of the MAP range.
This used to be pretty even, the stroker and cam has made a bigger difference than the head cam change a long time ago. I guess it would make a bigger difference, as its quite a big change.
Great news that the TA passed the MOT and is back on the road Dan. Sorry I was unable to help with the final reassembly last weekend due to being away. I liked your comment that your dear Mum heard it coming..awesome!
I was gutted that I wasn't able to be there for the first start up and thanks for sending me the video clip. Looking forward to hearing if first hand up the hill in the morning!!
The car was soo close before you went away, although I must have put in 12hours of putting the last bits on over that bank holiday. Would have been great if you were there, seeing all that work come to life. You really helped me out a lot. Never gone that far into an engine. We can say every bolt of that engine was removed, cleaned or replaced. A job well done.
Is this year/manufacturer/model locked or can you start selling your skills?
Well once this tank of fuel has gone, that will be pretty much time for another oil change.
The question is, what oil to get. some people say Fully synthetic is a no no, but then some people say that is the way to go. So I don't know what to go for.
I used to run semi-synthetic, but what I ran in the past may not be best to go on, as I got engine damage.
I looked in the workshop manual.
It says the weight is critical. i am currently running 10w30 which is correct for our current temperatures. I cant find in the book where it mentions mineral, semi-synthetic or fully synthetic only the weight.
Opie Oils have
Fuchs - Fuchs TITAN Uni HD SAE 10W/30 Uni Engine Oil
Redline - Synthetic RED LINE High Performance Synthetic Motor Oil 10w-30
Motul - Mineral Motul 4000 Motion 10W-30 Mineral Car Engine Oil
