Seconding what Chris said, although I have never broken a cam with roller lifters before so perhaps the process is different.
Hard to say from a cellphone clip but did sound tappy? Header leak?
I can hear clicking on the passenger side. Had that before when a coil pack was arching, although cant see the arching this time. Will investigate. When I first started it up it was more ticking until oil pressure pumped up the lifters. All lifters should be perfect, as checked each one manually by tuning over engine by hand and feeling all pushrods, everything was done to spec and all even. So I'm happy that is all fine. What is common is high lift cams creating noise though the plastic intake. It seems to be the same in all videos I've watched of other LS1 with non standard cam shafts. However I will be running more checks and tuning before taking it out on the road again.
I should be happy with the running of it by Sunday, ready for the Hayling show. 49 miles to go until an oil change.
