More like brial for blind people lol
Maybe you will have to use coloured capital letters![]()
Bet you wish if was a Plymouth Duster.View attachment 161818View attachment 161817View attachment 161819
working on the dacia duster today, had knocking on car found center bearing support for prop shaft split and also found the rear brake material had come away from shoe inside drum wow, we hurd knocking yesterday when we moved car from drive to ramp and wen we took car of ramp the rear wheel locked up so luck it didnt happen on the road so now waiting on lots of parts as exhaust hanger rubber is very soft as well
Thanks for that. I've not used Summit before so the info is useful and welcome. I've already ordered the kit for the Holley but returning to a standard carb could be an option. From what I can see, everything else is standard, so I doubt there would be any negatives by going back to a standard carb.Summit racing have stock of the correct type of carbs if you wanted to identify and fit the correct one and ditch the Holley.
Summit easy to use I brought a carb from them bolted straight already set up and turned its never missed a beat I rebuild mine with a rockauto kit wasn't very good so brought a reman from summit.
Thanks for that. Rockauto have standard carbs too from £230 plus shipping. As I've already ordered the kit, I'll try rebuilding the Holley first and see how that goes.Summit easy to use I brought a carb from them bolted straight already set up and turned its never missed a beat I rebuild mine with a rockauto kit wasn't very good so brought a reman from summit.
In my experience of drum brakes, if you peel back the end rubbers of the cylinders and it is still dry underneath (no brake fluid) and provided the pistons can be moved, they'll probably be OK to leave. It'll save having to crack open the hydraulic system and bleed it if you don't have to and if there were no problems with it.Going to take the other brake drum of the Duster ( named the car for you lol) see if any damage to that side even tho I will be changing all the brake shoes tempted to do the cylinders as well? At least it will be ready to put back together once all parts turn up..
It's amazing how the linings have fallen off the shoes! Has the car been reversed into the sea?! lol.This is the other side yes agree think we will leave the cylinder alone. But new spring brake kit ordered as well.
View attachment 161837View attachment 161841
