About to order parts, and the 383 stroker kit is in the parts list. The eagle stroker kit wan't in stock. Even Eagle do not have a complete kit. So the parts play have come up with a kit for me., which has a K1 crank, scat rods, wiseco pistons and clevite bearings.
The CC of the pistons is to be decided. I know when I brought my heads and cam package there were two CC sizes fort the heads. I think may was a couple of CC below stock which I believe is 67cc, and I think my heads are 63cc, I do recall them having a 59cc on the selection, but I cannot be sure what one I went for. I believe stock compression ratio is about 10.2, and I thought at the time I had increased it to 10.78.
Anyway to be sure I have a compression ration between 10.5 and 11:1 then I must measure the CC of the heads so the correct pistons can be chosen.
This is how it is done.
[video=youtube;yqAr4DUqEt4]https://www.youtube.com/watch?v=yqAr4DUqEt4[/video]
I have my bit of plastic. Thought I had loads of polycarbonate around, but resorted to a CD case, however it doesn't drill well, hence the tape.
Now I need some coloured water (I can make yellow), also need a syringe with measurements on the side.
